Ana içeriğe geç
Pantech Breakout Micro SD/SIM Card Replacement
  1. Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: adım 1, 3 resimden 1. Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: adım 1, 3 resimden 2. Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: adım 1, 3 resimden 3.
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: adım 2, 2 resimden 1. Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: adım 2, 2 resimden 2.
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
    FixBot'a Sor
    Yorum Ekle
  3. Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: adım 3, 2 resimden 1. Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: adım 3, 2 resimden 2.
    • The slots for the Micro SD and SIM cards are directly above the battery tray.
    • To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
    • Micro SD Card Slot - On the Left
    • SIM Card Slot - On the Right
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ryan Murphy
898 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Mcgee Fall 2014 USF Tampa, Team 5-5, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G5
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 2,966
