Ana içeriğe geç
Pantech CDM8975 Keyboard Replacement
Neye ihtiyacın var
  1. Pantech CDM8975 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the battery.
    • Remove four Phillips screws.
  2. Pantech CDM8975 Keyboard Replacement: adım 2, 1 resimden 1.
    • Pry up the plastic layer with a plastic opening tool.
    • NOTE: Be careful that you do not separate the two plastic parts completely they are fragile and may break if pulled too hard.
  3. Pantech CDM8975 Keyboard Replacement, Remove Keyboard: adım 3, 1 resimden 1.
    • Slide out the keyboard carefully in between the two layers.
  4. Pantech CDM8975 Keyboard Replacement: adım 4, 1 resimden 1.
    • Insert the new keyboard in between the two layers carefully.
  5. Pantech CDM8975 Keyboard Replacement: adım 5, 1 resimden 1.
    • Check if the edges are perfectly aligned between the two plastic layers after you insert the keyboard.
  6. Pantech CDM8975 Keyboard Replacement: adım 6, 1 resimden 1.
    • Press the two plastic layers back together.
    • Reinsert the four screws and place the battery and cover back.
Sonuç
You now have a new keyboard.
2 farklı kişi bu kılavuzu tamamladı.
Richard
116 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-4, Meza Spring 2014 Ohio State, Team 1-4, Meza Spring 2014 üyesi
OSU-MEZA-S14S1G4
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 63
Her zaman: 526
