Ana içeriğe geç
Pantech Matrix Keypad Replacement
Neye ihtiyacın var
  1. Pantech Matrix Keypad Replacement, Phone Orientation: adım 1, 1 resimden 1.
    • Place phone with screen side facing toward you.
    FixBot'a Sor
    Yorum Ekle
  2. Pantech Matrix Keypad Replacement, Phone Orientation: adım 2, 1 resimden 1.
    • Flip phone over so screen side is now facing down.
    FixBot'a Sor
    Yorum Ekle
  3. Pantech Matrix Keypad Replacement, Remove Back Cover: adım 3, 2 resimden 1. Pantech Matrix Keypad Replacement, Remove Back Cover: adım 3, 2 resimden 2.
    • Gently slide the backside phone cover off exposing the battery underneath.
    FixBot'a Sor
    Yorum Ekle
  4. Pantech Matrix Keypad Replacement, Lift Battery: adım 4, 1 resimden 1.
    • Carefully lift the battery up from where the spudger is pointed.
    FixBot'a Sor
    Yorum Ekle
  5. Pantech Matrix Keypad Replacement, Remove Battery: adım 5, 1 resimden 1.
    • Remove the battery from its dock.
    FixBot'a Sor
    Yorum Ekle
  6. Pantech Matrix Keypad Replacement, Slide SIM Card Out: adım 6, 3 resimden 1. Pantech Matrix Keypad Replacement, Slide SIM Card Out: adım 6, 3 resimden 2. Pantech Matrix Keypad Replacement, Slide SIM Card Out: adım 6, 3 resimden 3.
    • Slide the SIM Card out of its dock.
    FixBot'a Sor
    Yorum Ekle
  7. Pantech Matrix Keypad Replacement, Remove Phone Screws: adım 7, 2 resimden 1. Pantech Matrix Keypad Replacement, Remove Phone Screws: adım 7, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Pantech Matrix Keypad Replacement, Remove Phone Casing: adım 8, 2 resimden 1. Pantech Matrix Keypad Replacement, Remove Phone Casing: adım 8, 2 resimden 2.
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
    FixBot'a Sor
    Yorum Ekle
  9. Pantech Matrix Keypad Replacement, Remove Camera Screws: adım 9, 2 resimden 1. Pantech Matrix Keypad Replacement, Remove Camera Screws: adım 9, 2 resimden 2.
    • Place phone with exposed motherboard facing you.
    • Use a Phillips screwdriver to remove the five 2mm Phillips #000 screws holding the camera in place.
    FixBot'a Sor
    Yorum Ekle
  10. Pantech Matrix Keypad Replacement, Expose Keypad: adım 10, 1 resimden 1.
    • Carefully lift up the motherboard to expose the back of the keypad.
    FixBot'a Sor
    Yorum Ekle
  11. Pantech Matrix Keypad Replacement, Remove Keypad: adım 11, 2 resimden 1. Pantech Matrix Keypad Replacement, Remove Keypad: adım 11, 2 resimden 2.
    • Use spudger to gently pry the keypad away from the rest of the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zeel Patel
1.096 İtibar
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 458
