Ana içeriğe geç
Parrot AR.Drone 2.0 Propeller and Gear Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Parrot AR.Drone 2.0 Propeller and Gear Replacement, Propeller and Gear: adım 1, 2 resimden 1. Parrot AR.Drone 2.0 Propeller and Gear Replacement, Propeller and Gear: adım 1, 2 resimden 2.
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Propeller and Gear Replacement: adım 2, 2 resimden 1. Parrot AR.Drone 2.0 Propeller and Gear Replacement: adım 2, 2 resimden 2.
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Propeller and Gear Replacement: adım 3, 1 resimden 1.
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Propeller and Gear Replacement: adım 4, 3 resimden 1. Parrot AR.Drone 2.0 Propeller and Gear Replacement: adım 4, 3 resimden 2. Parrot AR.Drone 2.0 Propeller and Gear Replacement: adım 4, 3 resimden 3.
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
David Hoyt
4.053 İtibar
41 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G89
4 Üyeler
61 adet Kılavuz yazıldı
1Rehber Yorum
any idea how to change the little gear?
Dar BS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 8,684
