Giriş
This guide will show the steps needed to remove the GPS Module. In order to remove the GPS Module, the nose will have to be removed first. Removing the GPS Module will require disconnecting the wire connections on it.
Neye ihtiyacın var
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
With voice driving directions maps <a href="https://play.google.com/store/apps/detai...
">GPS Voice Nevigation with speed</a> limits with speaking ,user can get accurate gps coordinates for car GPS navigation.In gps driving guide 2019 users can listen to voice input for voice navigation which gives out all of the audio instructions for direction gps towards destination point on the maps
