Ana içeriğe geç
Parrot Bebop Drone Rubber Shock Absorbers Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Parrot Bebop Drone Rubber Shock Absorbers Replacement, Battery: adım 1, 2 resimden 1. Parrot Bebop Drone Rubber Shock Absorbers Replacement, Battery: adım 1, 2 resimden 2.
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 2, 2 resimden 1. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 2, 2 resimden 2.
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 3, 3 resimden 1. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 3, 3 resimden 2. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 3, 3 resimden 3.
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone Rubber Shock Absorbers Replacement, Styrofoam Nose: adım 4, 2 resimden 1. Parrot Bebop Drone Rubber Shock Absorbers Replacement, Styrofoam Nose: adım 4, 2 resimden 2.
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 5, 1 resimden 1.
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 6, 1 resimden 1.
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
  7. Parrot Bebop Drone Rubber Shock Absorbers Replacement, Rubber Shock Absorbers: adım 7, 2 resimden 1. Parrot Bebop Drone Rubber Shock Absorbers Replacement, Rubber Shock Absorbers: adım 7, 2 resimden 2.
    • Disconnect the two connectors that are attached to the front of the motherboard by gently pulling on the three wires.
  8. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 8, 1 resimden 1.
    • Remove the four 5mm torx T5 screws on the bottom of the drone with a Torx Screwdriver.
  9. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 9, 1 resimden 1.
    • Lightly pull up using the plastic opening tool to remove the back cover.
  10. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 10, 2 resimden 1. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a small pair of tweezers remove the two antenna wires attached to the motherboard.
    • When reconnecting the antenna wires to the motherboard, use the tweezers to place the connector on top of the connection plate and using the 150 mm Flex Extension push down on the gold connector to snap it in place.
  11. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 11, 1 resimden 1.
    • Remove the four wheel fasteners holding the frame together.
    • Hand turn or use a small plier, if tight to loosen the wheel fasteners.
  12. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 12, 3 resimden 1. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 12, 3 resimden 2. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 12, 3 resimden 3.
    • Using both hands gently pull the two pieces of the frame apart until you can see the connectors under the frame attached to the motherboard.
    • Remove both of the connectors from the motherboard. There is one connector on each side.
    • Do not fully remove the frame until both of the connectors are detached from the motherboard.
  13. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 13, 2 resimden 1. Parrot Bebop Drone Rubber Shock Absorbers Replacement: adım 13, 2 resimden 2.
    • Remove the four rubber shock absorbers by squeezing and twisting them while also pulling up.
    • Insert replacement rubber shock absorbers by placing one side in the hole and pushing down. Verify the shock absorbers are seated with a gentle tug.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jas Banwait
221 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-3, Rose Winter 2017 UW Tacoma, Team 1-3, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 1,077
