Ana içeriğe geç
Parrot Bebop Drone Styrofoam Nose Replacement
Neye ihtiyacın var
  1. Parrot Bebop Drone Styrofoam Nose Replacement, Battery: adım 1, 2 resimden 1. Parrot Bebop Drone Styrofoam Nose Replacement, Battery: adım 1, 2 resimden 2.
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone Styrofoam Nose Replacement: adım 2, 2 resimden 1. Parrot Bebop Drone Styrofoam Nose Replacement: adım 2, 2 resimden 2.
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone Styrofoam Nose Replacement: adım 3, 3 resimden 1. Parrot Bebop Drone Styrofoam Nose Replacement: adım 3, 3 resimden 2. Parrot Bebop Drone Styrofoam Nose Replacement: adım 3, 3 resimden 3.
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone Styrofoam Nose Replacement, Styrofoam Nose: adım 4, 2 resimden 1. Parrot Bebop Drone Styrofoam Nose Replacement, Styrofoam Nose: adım 4, 2 resimden 2.
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone Styrofoam Nose Replacement: adım 5, 1 resimden 1.
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone Styrofoam Nose Replacement: adım 6, 1 resimden 1.
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
Sonuç
To reassemble your device, follow these intructions in reverse order
2 farklı kişi bu kılavuzu tamamladı.
Jamuna Budhathoki
137 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-3, Rose Winter 2017 UW Tacoma, Team 1-3, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 943
