Ana içeriğe geç
Parrot FLYPAD Joystick Replacement
Neye ihtiyacın var
  1. Parrot FLYPAD Joystick Replacement, Joystick: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Total of 6 Screws are located in the back of the controller.
    • Four 0.9mm T6 screws
    • Two 0.1mm T6 screws
    • Flip the Flypad over.
    • Remove the six screws using a T6 screwdriver.
    • Use a Magnetic Mat to prevent loss of screws. Set aside.
  2. Parrot FLYPAD Joystick Replacement: adım 2, 1 resimden 1.
    • Flip the Flypad over again and separate the front and back. Be sure to remove the foam adhesive that connects the front plate to the motherboard.
    • Be aware that the Buttons (L1,R1) may fall out. Remember to put them back in place during reassembly.
    • Use Ph0 tool to remove the screws holding the motherboard in place.
    • Gently remove the motherboard from the front plate.
  3. Parrot FLYPAD Joystick Replacement: adım 3, 2 resimden 1. Parrot FLYPAD Joystick Replacement: adım 3, 2 resimden 2.
    • Pop the joysticks out by pulling gently.
  4. Parrot FLYPAD Joystick Replacement: adım 4, 1 resimden 1.
    • Unscrew and replace joystick caps for a more comfortable grip.
Sonuç
HUY NGUYEN
376 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G5, Liner Spring 2017 UW Tacoma, Team S3-G5, Liner Spring 2017 üyesi
UWT-LINER-S17S3G5
5 Üyeler
2 Yorum
Do you know where I can find replacement joystick caps like the one shown in Step 4, please?
cbeilstein - Yanıt
Same question as above regarding joystick caps please
Alex - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 688
