Giriş
I've got a Parrot Mambo that flew itself into the ground a little too hard. My friend brought it to me to see if I could remedy a solution. What I found was that the brushed motor had been completely ripped from its contacts; thus leaving no option but to replace it.
Neye ihtiyacın var
This motor is the defective one. The motor shaft is allowed to move freely up and down. Mine was the front right motor.
Flip quadcopter over to its underside
Use spudger or your fingernail to get underneath the rubber foot.
Remove rubber foot
Use the T4 driver to remove 4 screws.
Gently lift up the panel starting from the rear of the quad, and unhooking from the lip on the front.
You will now disconnect the motor wires that correspond to the motor you are replacing. I had to disconnect the rear right in order to correctly rewire the front right motor.
Pull gently on the wire and use the spudger to pop the connector out of its socket
Pull wires free from board
Grasp the motor you want to remove in one hand and the frame in the other and pull firmly to pull the motor out.
My motor did not work because the contacts were broken in the crash. Thus, the motor separated from its contacts.
10 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Actually, a T3 Torx driver / bit is needed, not a T4.
Yes, that is very small.
Quick Question are the 2 back motors consider motor. “C” ?? Thanks Appericate this
Motor C is front left and rear right
