Ana içeriğe geç
Parrot Skycontroller 2 Battery Replacement
Neye ihtiyacın var
  1. Parrot Skycontroller 2 Battery Replacement, Battery: adım 1, 3 resimden 1. Parrot Skycontroller 2 Battery Replacement, Battery: adım 1, 3 resimden 2. Parrot Skycontroller 2 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Flip your controller face down.
    FixBot'a Sor
    Yorum Ekle
  2. Parrot Skycontroller 2 Battery Replacement: adım 2, 1 resimden 1.
    • Remove one 9mm screw using a #4 flathead screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Parrot Skycontroller 2 Battery Replacement: adım 3, 3 resimden 1. Parrot Skycontroller 2 Battery Replacement: adım 3, 3 resimden 2. Parrot Skycontroller 2 Battery Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
    FixBot'a Sor
    Yorum Ekle
  4. Parrot Skycontroller 2 Battery Replacement: adım 4, 3 resimden 1. Parrot Skycontroller 2 Battery Replacement: adım 4, 3 resimden 2. Parrot Skycontroller 2 Battery Replacement: adım 4, 3 resimden 3.
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
    FixBot'a Sor
    Yorum Ekle
  5. Parrot Skycontroller 2 Battery Replacement: adım 5, 2 resimden 1. Parrot Skycontroller 2 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery from its brackets by pulling up on the ends of the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 58
Her zaman: 3,543
