Ana içeriğe geç
Parrot Skycontroller 2 Joystick Replacement
Neye ihtiyacın var
  1. Parrot Skycontroller 2 Joystick Replacement, Battery: adım 1, 3 resimden 1. Parrot Skycontroller 2 Joystick Replacement, Battery: adım 1, 3 resimden 2. Parrot Skycontroller 2 Joystick Replacement, Battery: adım 1, 3 resimden 3.
    • Flip your controller face down.
    FixBot'a Sor
    Yorum Ekle
  2. Parrot Skycontroller 2 Joystick Replacement: adım 2, 1 resimden 1.
    • Remove one 9mm screw using a #4 flathead screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Parrot Skycontroller 2 Joystick Replacement: adım 3, 3 resimden 1. Parrot Skycontroller 2 Joystick Replacement: adım 3, 3 resimden 2. Parrot Skycontroller 2 Joystick Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
    FixBot'a Sor
    Yorum Ekle
  4. Parrot Skycontroller 2 Joystick Replacement: adım 4, 3 resimden 1. Parrot Skycontroller 2 Joystick Replacement: adım 4, 3 resimden 2. Parrot Skycontroller 2 Joystick Replacement: adım 4, 3 resimden 3.
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
    FixBot'a Sor
    Yorum Ekle
  5. Parrot Skycontroller 2 Joystick Replacement: adım 5, 2 resimden 1. Parrot Skycontroller 2 Joystick Replacement: adım 5, 2 resimden 2.
    • Remove the battery from its brackets by pulling up on the ends of the battery.
    FixBot'a Sor
    Yorum Ekle
  6. Parrot Skycontroller 2 Joystick Replacement, Joystick: adım 6, 1 resimden 1.
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screws using the Torx TR6 screwdriver
    FixBot'a Sor
    Yorum Ekle
  7. Parrot Skycontroller 2 Joystick Replacement: adım 7, 3 resimden 1. Parrot Skycontroller 2 Joystick Replacement: adım 7, 3 resimden 2. Parrot Skycontroller 2 Joystick Replacement: adım 7, 3 resimden 3.
    • Remove the seven silver 4mm screws from around the edge of the top plate with the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
    FixBot'a Sor
    Yorum Ekle
  8. Parrot Skycontroller 2 Joystick Replacement: adım 8, 1 resimden 1.
    • Remove the battery compartment plate by pulling up and out.
    FixBot'a Sor
    Yorum Ekle
  9. Parrot Skycontroller 2 Joystick Replacement: adım 9, 1 resimden 1.
    • Remove the top plate by pushing out on the corners with your hand.
    • Be careful to not pull too hard on the cable.
    FixBot'a Sor
    Yorum Ekle
  10. Parrot Skycontroller 2 Joystick Replacement: adım 10, 2 resimden 1. Parrot Skycontroller 2 Joystick Replacement: adım 10, 2 resimden 2.
    • Remove the face plate by pulling up and out.
    • Buttons will fall out when this plate is removed.
    FixBot'a Sor
    Yorum Ekle
  11. Parrot Skycontroller 2 Joystick Replacement: adım 11, 3 resimden 1. Parrot Skycontroller 2 Joystick Replacement: adım 11, 3 resimden 2. Parrot Skycontroller 2 Joystick Replacement: adım 11, 3 resimden 3.
    • Firmly grasp the end of either joystick.
    • Pull the joystick up and out while grasping the other side of the controller.
    • Once both joysticks have been removed, this is what it should look like.
    • Some force may be needed to remove the joysticks.
    • Repeat this process for the other side as well.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 760
