Ana içeriğe geç
Patch a Car Tire Patching Replacement
Neye ihtiyacın var
  1. Patch a Car Tire Patching Replacement, Identify leak: adım 1, 1 resimden 1.
    • Look around the tire to see if there is any nail, cracks, or holes.
    • Once the leak is found, mark it.
  2. Patch a Car Tire Patching Replacement, Evacuate air: adım 2, 1 resimden 1.
    • Once the leak is identified, evacuate the air from the tire using the valve stem removal tool
    • Be sure to keep the small valve stem to reinstall after finished.
  3. Patch a Car Tire Patching Replacement, Remove tire from wheel: adım 3, 1 resimden 1.
    • Lay the wheel on the tire machine and use the tire iron to pull out the upper bead.
    • Use the tire machine to spin the wheel counter-clockwise.
    • Make sure to keep a strong grip on the tire iron otherwise it can jerk itself out.
  4. Patch a Car Tire Patching Replacement, Remove tire (cont.): adım 4, 1 resimden 1.
    • Once the upper bead is lifted off the wheel, remove the lower bead
  5. Patch a Car Tire Patching Replacement, Remove nail (if applicable): adım 5, 1 resimden 1.
    • Once the tire is removed from the wheel, removed the nail from the tire using the dikes
  6. Patch a Car Tire Patching Replacement, Place tire on a secure surface: adım 6, 1 resimden 1.
    • Place the tire on a secure and well lit area to prepare for a patch by grinding the inside of the tire
  7. Patch a Car Tire Patching Replacement, Grind around the puncture: adım 7, 1 resimden 1.
    • Use the die grinder to grind around the puncture to leave enough room for a patch to stick
    • Be sure to use a strong grip with a lot of pressure to keep the die grinder in control.
  8. Patch a Car Tire Patching Replacement, Grind around the puncture (cont.): adım 8, 1 resimden 1.
    • The surface area of the grinded area must be level and larger than the patch
  9. Patch a Car Tire Patching Replacement, Apply vulcanizing cement: adım 9, 1 resimden 1.
    • Apply an even layer of vulcanizing cement glue over the area that was grinded
  10. Patch a Car Tire Patching Replacement, Place the tire patch: adım 10, 1 resimden 1.
    • After the glue is dry, gently lay the patch at the center of the puncture.
    • The patch must be smaller than area that was grinded
  11. Patch a Car Tire Patching Replacement, Seal the Patch: adım 11, 2 resimden 1. Patch a Car Tire Patching Replacement, Seal the Patch: adım 11, 2 resimden 2.
    • Use the stitch roller to roll the patch in a crisscross pattern onto the tire for a permanent seal
  12. Patch a Car Tire Patching Replacement, Reinstall the tire: adım 12, 1 resimden 1.
    • Put the tire back onto the tire machine.
    • Start by installing the lower bead
  13. Patch a Car Tire Patching Replacement, Reinstall the tire (cont.): adım 13, 2 resimden 1. Patch a Car Tire Patching Replacement, Reinstall the tire (cont.): adım 13, 2 resimden 2.
    • After the lower bead is on the wheel
    • Use the tire iron to install the upper bead
    • Use a firm grip on the tire iron or it can swing back towards you.
  14. Patch a Car Tire Patching Replacement, Inflate the tire: adım 14, 1 resimden 1.
    • Use the air hose to inflate the tire to the correct psi
    • Typically, air pressure should be around 35-40 psi.
    • Insert the small tire valve stem you saved from earlier
  15. Patch a Car Tire Patching Replacement, Finished: adım 15, 1 resimden 1.
    • Job well done!
Sonuç
Now that your repair is finished, it safe to say that you have given the tire a second chance by extending its life. You saved money by reusing this tire, additionally lowering the amount of rubber waste that is demolishing our environment.
Bir başkası bu kılavuzu tamamladı.
Justin Guerra
283 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 83
Her zaman: 1,869
