Ana içeriğe geç
Patch your Patagonia Nano Puff ® Jacket with Repair Tape
Neye ihtiyacın var
  1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape, Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 1, 1 resimden 1.
    • Inspect the damage on your jacket. Clip any dangling threads or fabric using small scissors.
  2. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 2, 3 resimden 1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 2, 3 resimden 2. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 2, 3 resimden 3.
    • Grab your repair tape.
    • Flip the repair tape to the back side.
    • Using a permanent marker, draw an oval slightly larger than the hole.
    • If you have a wide hole, you can use a rectangle, but be sure to round the edges. Rounding the edges prevents the corners from getting caught and peeling up.
  3. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 3, 2 resimden 1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 3, 2 resimden 2.
    • Cut out your shape using scissors.
  4. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 4, 3 resimden 1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 4, 3 resimden 2. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 4, 3 resimden 3.
    • Using your fingernail, or a pin, peel the backing off the tenacious tape, so that you only have the clear sticky layer.
    • Be sure not to touch the sticky side of the tape as this will gum up the tape and it won’t stick well.
  5. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 5, 2 resimden 1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 5, 2 resimden 2.
    • Lay the tape over the hole and press the tape down with your finger.
  6. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 6, 2 resimden 1. Patch your Patagonia Nano Puff ® Jacket with Repair Tape: adım 6, 2 resimden 2.
    • Use a fingernail or spudger to work out all of the air bubbles under the tape. Continue rubbing the tape until it is well-adhered.
Bitiş Çizgisi
9 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
89.020 İtibar
131 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.299 adet Kılavuz yazıldı
2 Yorum
I followed this tutorial and used Tenacious tape by Gear Aid because it claims to not leave a residue behind if removed. That was a bad idea. I am now ready to upgrade this patch to a sewn one and removing the tape is absolutely leaving behind a residue. Really annoyed right now.
Ling Wang - Yanıt
This is really helpful, thanks.
James
James Riley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 145
Her zaman: 45,380
