Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Inspect the damage on your jacket. Clip any dangling threads or fabric using small scissors.
Grab your repair tape.
Flip the repair tape to the back side.
Using a permanent marker, draw an oval slightly larger than the hole.
Using your fingernail, or a pin, peel the backing off the tenacious tape, so that you only have the clear sticky layer.
Lay the tape over the hole and press the tape down with your finger.
Use a fingernail or spudger to work out all of the air bubbles under the tape. Continue rubbing the tape until it is well-adhered.
9 farklı kişi bu kılavuzu tamamladı.
2 Yorum
This is really helpful, thanks.
James
