Ana içeriğe geç
Patching a 125 2 stroke fuel tank
  1. Patching a 125 2 stroke fuel tank, Patching a 125 2 stroke fuel tank: adım 1, 1 resimden 1.
    • First, you will need to sand down the rough edges around the hole in fuel tank.
    • Make sure the hole in the fuel tank and its surrounding is as smooth as possible.
  2. Patching a 125 2 stroke fuel tank: adım 2, 1 resimden 1.
    • Once the hole is smooth. Apply fuel patch with q-tip over hole and the surrounding edges.
  3. Patching a 125 2 stroke fuel tank: adım 3, 1 resimden 1.
    • Make sure that the ointment is spread thickly over the hole.
  4. Patching a 125 2 stroke fuel tank: adım 4, 1 resimden 1.
    • Avoid having air pockets in the ointment. Air pockets may make the patch less effective or not seal at all.
    • Once the ointment is spread over smoothly, you will need to rub the edges out so there is no edge that can be caught on something.
  5. Patching a 125 2 stroke fuel tank: adım 6, 1 resimden 1.
    • Let the patch dry over.
    • Try not to touch patch until completely dry. This may take a couple hours.
  6. Patching a 125 2 stroke fuel tank: adım 7, 1 resimden 1.
    • Next, you will need to check the patch after completely dry. Make sure there is no bubbles or edges where there could be another potential leak.
    • Once patch is dry put fuel in the tank.
    • When tank is full check to see if there are any leaks in the patch. Leaks consist of fuel dripping or even air leak from patch.
    • If there are leaks scrape off patch and repeat process.
  7. Patching a 125 2 stroke fuel tank: adım 11, 1 resimden 1.
    • When there are no leaks start riding. Your tank is now patched. Check up on patch after ride to make sure it is still sealed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew
1.304 İtibar
2 adet Kılavuz yazıldı
Vegas Room H9 Vegas Room H9 üyesi
Community
13 Üyeler
16 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 548
