Ana içeriğe geç
Pebble Steel Vibration Motor Replacement
Neye ihtiyacın var
  1. Pebble Steel Vibration Motor Replacement, Internal Hardware: adım 1, 3 resimden 1. Pebble Steel Vibration Motor Replacement, Internal Hardware: adım 1, 3 resimden 2. Pebble Steel Vibration Motor Replacement, Internal Hardware: adım 1, 3 resimden 3.
    • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
    • Make sure the screws are kept in a safe place to insure they are not lost.
    • Remove the back plate.
    FixBot'a Sor
    Yorum Ekle
  2. Pebble Steel Vibration Motor Replacement: adım 2, 2 resimden 1. Pebble Steel Vibration Motor Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
    • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
    • Adhesive on the back side of the battery holds the internal components to the front case.
    • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  3. Pebble Steel Vibration Motor Replacement, Vibration Motor: adım 3, 1 resimden 1.
    • Use a small plastic opening tool to remove the vibration motor from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Pebble Steel Vibration Motor Replacement: adım 4, 1 resimden 1.
    • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Orlandria Heggs
545 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-7, Leahy Fall 2015 USF Tampa, Team 1-7, Leahy Fall 2015 üyesi
USFT-LEAHY-F15S1G7
3 Üyeler
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - Yanıt Paylaş
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 3,851
