Giriş
Would you like to switch out the watch band on your Pebble Steel from leather to metal or vice versa? This guide will show you how.
Neye ihtiyacın var
Bu adımda kullanılan alet:Flathead 1.5 mm Screwdriver$5.49
Place the watch on its side to expose the side pins.
Use a 1.5 mm flathead screwdriver to unscrew the pin that is holding the band.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
One of my Pebble Steel pins comes out just as expected, but the other just spins, and doesn’t come out. Any ideas?
