Ana içeriğe geç
Pebble Time Battery Replacement
Neye ihtiyacın var
    1. Pebble Time Battery Replacement, Screen Cover: adım 1, 1 resimden 1.
      • Lay the watch flat on your workstation.
      FixBot'a Sor
      Yorum Ekle
    2. Pebble Time Battery Replacement: adım 2, 2 resimden 1. Pebble Time Battery Replacement: adım 2, 2 resimden 2.
      • Use the metal spudger to carefully pull apart the screen cover from the case.
      • Replace the metal spudger with a plastic opening tool to hold the cover open.
      FixBot'a Sor
      Yorum Ekle
    3. Pebble Time Battery Replacement: adım 3, 1 resimden 1.
      • Use the metal spudger tool to carefully loosen the rest of the cover.
      FixBot'a Sor
      Yorum Ekle
    4. Pebble Time Battery Replacement: adım 4, 1 resimden 1.
      • Carefully, pull apart the cover with the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    1. Pebble Time Battery Replacement, Screen: adım 5, 1 resimden 1.
      • Insert metal spudger into the side of the screen shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    2. Pebble Time Battery Replacement: adım 6, 1 resimden 1.
      • Use the metal spudger to pry the screen up.
      FixBot'a Sor
      Yorum Ekle
    3. Pebble Time Battery Replacement: adım 7, 3 resimden 1. Pebble Time Battery Replacement: adım 7, 3 resimden 2. Pebble Time Battery Replacement: adım 7, 3 resimden 3.
      • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
      • Disconnect the screen from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    1. Pebble Time Battery Replacement, Circuit Board: adım 8, 1 resimden 1.
      • Keep the watch flat on your workstation.
      FixBot'a Sor
      Yorum Ekle
    2. Pebble Time Battery Replacement: adım 9, 1 resimden 1.
      • Locate the three screws on the circuit board.
      • Remove using the J000 Philips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Pebble Time Battery Replacement: adım 10, 3 resimden 1. Pebble Time Battery Replacement: adım 10, 3 resimden 2. Pebble Time Battery Replacement: adım 10, 3 resimden 3.
      • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
      • Move apart the connector to expose the fourth screw.
      FixBot'a Sor
      Yorum Ekle
    4. Pebble Time Battery Replacement: adım 11, 1 resimden 1.
      • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Pebble Time Battery Replacement: adım 12, 2 resimden 1. Pebble Time Battery Replacement: adım 12, 2 resimden 2.
      • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
      • Remove the circuit board from the case.
      FixBot'a Sor
      Yorum Ekle
    1. Pebble Time Battery Replacement, Battery: adım 13, 1 resimden 1.
      • After removing the circuit board, the battery is located in the middle of the case.
      FixBot'a Sor
      Yorum Ekle
    2. Pebble Time Battery Replacement: adım 14, 2 resimden 1. Pebble Time Battery Replacement: adım 14, 2 resimden 2.
      • Locate the battery connector on the left side of the case.
      • Carefully disconnect the wire using a metal spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Pebble Time Battery Replacement: adım 15, 2 resimden 1. Pebble Time Battery Replacement: adım 15, 2 resimden 2.
      • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
      • The battery might be glued to the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
35 farklı kişi bu kılavuzu tamamladı.
Nicolas Hempe
1.516 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G3
4 Üyeler
10 adet Kılavuz yazıldı
12Kılavuz Yorumları
Where did you purchase the replacement battery?
Dimas Caparros - Yanıt Paylaş
Got mine on Amazon
kwojdak - Yanıt Paylaş
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Shannon Oswald - Yanıt Paylaş
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
There’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”.
Xie Yanbo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 36
Son 30 gün: 191
Her zaman: 27,720
