Ana içeriğe geç
Pebble Time Circuit Board Replacement
Neye ihtiyacın var
  1. Pebble Time Circuit Board Replacement, Screen Cover: adım 1, 1 resimden 1.
    • Lay the watch flat on your workstation.
  2. Pebble Time Circuit Board Replacement: adım 2, 2 resimden 1. Pebble Time Circuit Board Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Circuit Board Replacement: adım 3, 1 resimden 1.
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Circuit Board Replacement: adım 4, 1 resimden 1.
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Circuit Board Replacement, Screen: adım 5, 1 resimden 1.
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Circuit Board Replacement: adım 6, 1 resimden 1.
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Circuit Board Replacement: adım 7, 3 resimden 1. Pebble Time Circuit Board Replacement: adım 7, 3 resimden 2. Pebble Time Circuit Board Replacement: adım 7, 3 resimden 3.
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
  8. Pebble Time Circuit Board Replacement, Circuit Board: adım 8, 1 resimden 1.
    • Keep the watch flat on your workstation.
  9. Pebble Time Circuit Board Replacement: adım 9, 1 resimden 1.
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Circuit Board Replacement: adım 10, 3 resimden 1. Pebble Time Circuit Board Replacement: adım 10, 3 resimden 2. Pebble Time Circuit Board Replacement: adım 10, 3 resimden 3.
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Circuit Board Replacement: adım 11, 1 resimden 1.
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Circuit Board Replacement: adım 12, 2 resimden 1. Pebble Time Circuit Board Replacement: adım 12, 2 resimden 2.
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
Sonuç
Nicolas Hempe
1.444 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 844
