Ana içeriğe geç
Pebble Time Screen Replacement
Neye ihtiyacın var
  1. Pebble Time Screen Replacement, Screen Cover: adım 1, 1 resimden 1.
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: adım 2, 2 resimden 1. Pebble Time Screen Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
  3. Pebble Time Screen Replacement: adım 3, 1 resimden 1.
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: adım 4, 1 resimden 1.
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: adım 5, 1 resimden 1.
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: adım 6, 1 resimden 1.
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: adım 7, 3 resimden 1. Pebble Time Screen Replacement: adım 7, 3 resimden 2. Pebble Time Screen Replacement: adım 7, 3 resimden 3.
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Saud Al-Malki
110 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Sullivan Spring 2017 USF Tampa, Team 1-3, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G3
4 Üyeler
7 adet Kılavuz yazıldı
3 Yorum
Where can I buy the display replacement?
ulises - Yanıt
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - Yanıt
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 28
Her zaman: 3,202
