Ana içeriğe geç
Penguin FZ-8 28” Tower Fan Blade Replacement
Neye ihtiyacın var
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: adım 1, 1 resimden 1.
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 2, 3 resimden 1. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 2, 3 resimden 2. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 2, 3 resimden 3.
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 3, 2 resimden 1. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 3, 2 resimden 2.
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 4, 2 resimden 1. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 4, 2 resimden 2.
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 5, 2 resimden 1. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 5, 2 resimden 2.
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 6, 2 resimden 1. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 6, 2 resimden 2.
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 7, 1 resimden 1.
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 8, 2 resimden 1. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 8, 2 resimden 2.
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: adım 9, 1 resimden 1.
    • Remove the fan blade from the device and clean it off before reassembling your device.
Sonuç
Ethan
169 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 1,194
