Ana içeriğe geç
Penn-Plax Cascade 20 Power Filter Impeller Replacement
Neye ihtiyacın var
  1. Penn-Plax Cascade 20 Power Filter Impeller Replacement, Impeller: adım 1, 1 resimden 1.
    • Start by placing filter system on your workstation of choice.
  2. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 2, 3 resimden 1. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 2, 3 resimden 2. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 2, 3 resimden 3.
    • Remove all detachable pieces from the filter. This includes the lid, pipe, and filter media.
  3. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 3, 3 resimden 1. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 3, 3 resimden 2. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 3, 3 resimden 3.
    • Take your filter and place it upside down.
    • Place your hand on the motor. Grab it firmly and turn it clockwise for a quarter turn. When the turn is complete, it should look like the second picture.
    • Pull the motor up and out from the filter chassis.
    • The motor should be able to be pulled off with ease.
  4. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 4, 3 resimden 1. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 4, 3 resimden 2. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 4, 3 resimden 3.
    • Take your index finger and thumb and firmly grip one of the impeller blades.
    • Pull the impeller up and out of the motor shaft.
    • You should feel mild resistance because the impeller is secured via magnet.
  5. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 5, 3 resimden 1. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 5, 3 resimden 2. Penn-Plax Cascade 20 Power Filter Impeller Replacement: adım 5, 3 resimden 3.
    • To install a new impeller, grab it by the fins and place it back into the motor shaft hole.
    • Push the new impeller in and make sure it is connected to the magnetic seal. This can be checked by flipping the motor upside down and seeing if the impeller falls out.
Sonuç
Your Penn-Plax Cascade 20 Power Filter should be up and running again!
Bir başkası bu kılavuzu tamamladı.
Danny Vo
145 İtibar
1 Kılavuz yazıldı
Ekip
UM-KIM-S22SM50G2 UM-KIM-S22SM50G2 üyesi
Community
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 556
