Ana içeriğe geç
Pentax LX Top Cover (Wind Side) Removal
Neye ihtiyacın var
  1. Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: adım 1, 3 resimden 1. Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: adım 1, 3 resimden 2. Pentax LX Top Cover (Wind Side) Removal, Remove winding lever: adım 1, 3 resimden 3.
    • Winding lever cover is reverse threaded.
    • Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
    • Remove four #000 2.5 mm screws.
    • Use spanners to remove top cover retaining nut.
  2. Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: adım 2, 3 resimden 1. Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: adım 2, 3 resimden 2. Pentax LX Top Cover (Wind Side) Removal, Remove shutter speed dial: adım 2, 3 resimden 3.
    • Gently remove the rubber covering around the shutter speed dial.
    • Remove three #000 1.6 mm screws.
    • Remove cover ring.
    • Installation Notes: After the camera has been fully tested, use a few dabs of contact cement to fix the rubber covering back in place.
  3. Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: adım 3, 3 resimden 1. Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: adım 3, 3 resimden 2. Pentax LX Top Cover (Wind Side) Removal, Remove wind side top cover: adım 3, 3 resimden 3.
    • Remove one #00 2.5 mm screw.
    • Remove one #00 X mm screw.
    • Lift off top cover.
Sonuç
Sam Gustafson
7.712 İtibar
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 35
Her zaman: 215
