Ana içeriğe geç
Pentax ME Super Top Cover Removal
Neye ihtiyacın var
  1. Pentax ME Super Top Cover Removal, Remove wind lever: adım 1, 3 resimden 1. Pentax ME Super Top Cover Removal, Remove wind lever: adım 1, 3 resimden 2. Pentax ME Super Top Cover Removal, Remove wind lever: adım 1, 3 resimden 3.
    • Wrap a piece of masking tape around your thumb, sticky side out.
    • Turn the wind lever cap clockwise to remove (it is reverse threaded).
    • Remove the wind lever lock ring (it is also reverse threaded).
    • Remove the brass spring washer.
    • A pair of fine tipped pliers or nippers can be used in place of a spanner wrench. Be careful!
  2. Pentax ME Super Top Cover Removal, Remove rewind lever: adım 2, 3 resimden 1. Pentax ME Super Top Cover Removal, Remove rewind lever: adım 2, 3 resimden 2. Pentax ME Super Top Cover Removal, Remove rewind lever: adım 2, 3 resimden 3.
    • Place a tool in the fork of the rewind spindle.
    • Unscrew the rewind lever.
    • Remove the lock ring with a spanner.
    • Lift off the ISO/Exposure Compensation dial.
  3. Pentax ME Super Top Cover Removal, Installation Notes: ISO dial: adım 3, 1 resimden 1.
    • Ensure that the ISO dial couples with the tab on the resistor.
    • Turn the Exposure Compensation to 1/4x then back to 4x while gently pushing down. This will help the dial engage with the detent mechanism properly.
  4. Pentax ME Super Top Cover Removal, Unscrew top cover: adım 4, 3 resimden 1. Pentax ME Super Top Cover Removal, Unscrew top cover: adım 4, 3 resimden 2. Pentax ME Super Top Cover Removal, Unscrew top cover: adım 4, 3 resimden 3.
    • Remove two 3.3 mm #00 screws.
    • Remove one 3.2 mm #00 screw.
    • Remove one 2.6 mm #00 screw.
  5. Pentax ME Super Top Cover Removal, Unscrew top cover: adım 5, 2 resimden 1. Pentax ME Super Top Cover Removal, Unscrew top cover: adım 5, 2 resimden 2.
    • Remove two 4.3 mm #00 screws.
  6. Pentax ME Super Top Cover Removal: adım 6, 2 resimden 1. Pentax ME Super Top Cover Removal: adım 6, 2 resimden 2.
    • Lift off the top cover. The silver trim piece is loose and may fall away.
    • Remove loose washer.
  7. Pentax ME Super Top Cover Removal, Installation Notes: Top Cover: adım 7, 1 resimden 1.
    • The shutter pin is loose. Make sure it is in place before installing the top cover.
    • The mode dial pin must be properly coupled with the mechanisms in the camera for it to work.
    • Set the mode dial to 'M'. Place the top cover on the camera. Move the mode dial to 'B' then back to 'M' while gently pushing down.
    • The mode dial should click into place and work properly.
Sonuç
Sam Gustafson
7.682 İtibar
42 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 49
Her zaman: 467
