Ana içeriğe geç
Pentax MX Top Cover Removal
Neye ihtiyacın var
    1. Pentax MX Top Cover Removal, Remove film advance lever: adım 1, 3 resimden 1. Pentax MX Top Cover Removal, Remove film advance lever: adım 1, 3 resimden 2. Pentax MX Top Cover Removal, Remove film advance lever: adım 1, 3 resimden 3.
      • Remove the lever cap. The cap is reverse threaded.
      • Lift off the advance lever.
      • Remove the collar beneath the lever.
      FixBot'a Sor
      Yorum Ekle
    2. Pentax MX Top Cover Removal, Remove shutter speed dial: adım 2, 2 resimden 1. Pentax MX Top Cover Removal, Remove shutter speed dial: adım 2, 2 resimden 2.
      • Set the ISO to 100 and the shutter speed to 1000.
      • Remove one pin head screw.
      • Lift off shutter speed dial.
      • Remove the collar beneath the dial.
      • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
      FixBot'a Sor
      Yorum Ekle
    3. Pentax MX Top Cover Removal, Remove rewind knob: adım 3, 3 resimden 1. Pentax MX Top Cover Removal, Remove rewind knob: adım 3, 3 resimden 2. Pentax MX Top Cover Removal, Remove rewind knob: adım 3, 3 resimden 3.
      • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
      • Remove the lock ring underneath the rewind knob.
      • Remove the cover plate.
      FixBot'a Sor
      Yorum Ekle
    4. Pentax MX Top Cover Removal, Remove top cover: adım 4, 3 resimden 1. Pentax MX Top Cover Removal, Remove top cover: adım 4, 3 resimden 2. Pentax MX Top Cover Removal, Remove top cover: adım 4, 3 resimden 3.
      • Remove two M1.7 x 3.2 mm screws.
      • Remove two M1.7 x 2 mm countersunk screws.
      • Lift off top cover.
      • The release cable pin in the shutter button is loose and may fall out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Sam Gustafson
14.444 İtibar
78 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 52
Her zaman: 210
