Ana içeriğe geç
Pentax MX Viewfinder Speed Indication Adjustment
Neye ihtiyacın var
    1. Pentax MX Viewfinder Speed Indication Adjustment, Remove film advance lever: adım 1, 3 resimden 1. Pentax MX Viewfinder Speed Indication Adjustment, Remove film advance lever: adım 1, 3 resimden 2. Pentax MX Viewfinder Speed Indication Adjustment, Remove film advance lever: adım 1, 3 resimden 3.
      • Remove the lever cap. The cap is reverse threaded.
      • Lift off the advance lever.
      • Remove the collar beneath the lever.
      FixBot'a Sor
      Yorum Ekle
    2. Pentax MX Viewfinder Speed Indication Adjustment, Remove shutter speed dial: adım 2, 2 resimden 1. Pentax MX Viewfinder Speed Indication Adjustment, Remove shutter speed dial: adım 2, 2 resimden 2.
      • Set the ISO to 100 and the shutter speed to 1000.
      • Remove one pin head screw.
      • Lift off shutter speed dial.
      • Remove the collar beneath the dial.
      • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
      FixBot'a Sor
      Yorum Ekle
    3. Pentax MX Viewfinder Speed Indication Adjustment, Remove rewind knob: adım 3, 3 resimden 1. Pentax MX Viewfinder Speed Indication Adjustment, Remove rewind knob: adım 3, 3 resimden 2. Pentax MX Viewfinder Speed Indication Adjustment, Remove rewind knob: adım 3, 3 resimden 3.
      • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
      • Remove the lock ring underneath the rewind knob.
      • Remove the cover plate.
      FixBot'a Sor
      Yorum Ekle
    4. Pentax MX Viewfinder Speed Indication Adjustment, Remove top cover: adım 4, 3 resimden 1. Pentax MX Viewfinder Speed Indication Adjustment, Remove top cover: adım 4, 3 resimden 2. Pentax MX Viewfinder Speed Indication Adjustment, Remove top cover: adım 4, 3 resimden 3.
      • Remove two M1.7 x 3.2 mm screws.
      • Remove two M1.7 x 2 mm countersunk screws.
      • Lift off top cover.
      • The release cable pin in the shutter button is loose and may fall out.
      FixBot'a Sor
      Yorum Ekle
    1. Pentax MX Viewfinder Speed Indication Adjustment, Detach viewfinder LED PCB: adım 5, 2 resimden 1. Pentax MX Viewfinder Speed Indication Adjustment, Detach viewfinder LED PCB: adım 5, 2 resimden 2.
      • Remove one M1.3 x 2.8 mm screw and washer.
      • Remove one M1.7 x 2.8 mm screw.
      • Pull the LED PCB out of the side of the mirror box.
      • Installation Notes: Install batteries and check the position of the LEDs. Position the PCB as needed then tighten the screws to fix it in place.
      FixBot'a Sor
      Yorum Ekle
    2. Pentax MX Viewfinder Speed Indication Adjustment, Install shutter speed dial: adım 6, 1 resimden 1.
      • Temporarily install the shutter speed dial.
      • Set the shutter speed to '1000'.
      • It can be helpful to tape the LED board out of the way while you work on the adjustment screws.
      FixBot'a Sor
      Yorum Ekle
    3. Pentax MX Viewfinder Speed Indication Adjustment, Course adjustment: adım 7, 3 resimden 1. Pentax MX Viewfinder Speed Indication Adjustment, Course adjustment: adım 7, 3 resimden 2. Pentax MX Viewfinder Speed Indication Adjustment, Course adjustment: adım 7, 3 resimden 3.
      • You can skip this step if the speed indicator is close to the correct position in the viewfinder.
      • Loosen but do not remove the slotted post.
      • Shift the idler gear so that it doesn't engage with the gear attached to the speed display.
      • Move the disc until '1000' is displayed roughly between the two points on the edge of the frame.
      • Move the idler gear back into position so that it meshes with the gear attached to the speed display.
      • If the speed display does not move smoothly in both directions when the shutter dial is turned, adjust the eccentric until the gears mesh properly.
      • Tighten the lock screw.
      FixBot'a Sor
      Yorum Ekle
    4. Pentax MX Viewfinder Speed Indication Adjustment, Fine adjustment: adım 8, 1 resimden 1.
      • Loosen the lock screw on the adjustment pulley. This screw is reverse threaded.
      • Turn the eccentric adjustment until '1000' is perfectly horizontal in the viewfinder.
      • Tighten the lock screw on the adjustment pulley.
      • Check the position of the indicators throughout the range of speeds. Repeat adjustment as necessary.
      FixBot'a Sor
      Yorum Ekle
    5. Pentax MX Viewfinder Speed Indication Adjustment, Vertical adjustment: adım 9, 1 resimden 1.
      • Loosen two screws.
      • Move the support plate up or down to center the number vertically.
      • This adjustment will translate the indicator dial rather than rotate it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Gustafson
14.454 İtibar
78 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 91
Her zaman: 350
