Ana içeriğe geç
Pentax Optio S4i Front and Back Cover Replacement
Neye ihtiyacın var
  1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: adım 1, 2 resimden 1. Pentax Optio S4i Front and Back Cover Replacement, Front and Back Cover: adım 1, 2 resimden 2.
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Pentax Optio S4i Front and Back Cover Replacement: adım 2, 1 resimden 1.
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Pentax Optio S4i Front and Back Cover Replacement: adım 3, 2 resimden 1. Pentax Optio S4i Front and Back Cover Replacement: adım 3, 2 resimden 2.
    • Carefully pull the back of casing away from the front.
  4. Pentax Optio S4i Front and Back Cover Replacement: adım 4, 3 resimden 1. Pentax Optio S4i Front and Back Cover Replacement: adım 4, 3 resimden 2. Pentax Optio S4i Front and Back Cover Replacement: adım 4, 3 resimden 3.
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Pentax Optio S4i Front and Back Cover Replacement: adım 5, 2 resimden 1. Pentax Optio S4i Front and Back Cover Replacement: adım 5, 2 resimden 2.
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicole Wong
329 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-29, Regan Winter 2011 Cal Poly, Team 4-29, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G29
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 3,230
