Ana içeriğe geç
Pentax Optio WG-2 Shutter and Power Button Replacement
Neye ihtiyacın var
  1. Pentax Optio WG-2 Shutter and Power Button Replacement, Shutter and Power Button: adım 1, 1 resimden 1.
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite from the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  2. Pentax Optio WG-2 Shutter and Power Button Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
Sonuç
Matthew Bessette
658 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 UMass Dartmouth, Team 6-7, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G7
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 270
