Ana içeriğe geç
Pentax Optio WG-3 GPS Flash Replacement
Neye ihtiyacın var
  1. Pentax Optio WG-3 GPS Flash Replacement, Flash: adım 1, 1 resimden 1.
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Flash Replacement: adım 2, 1 resimden 1.
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Flash Replacement: adım 3, 1 resimden 1.
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Flash Replacement: adım 4, 1 resimden 1.
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Flash Replacement: adım 5, 1 resimden 1.
    • Upon removing the flash, there is a 2 mm screw that needs to be removed.
  6. Pentax Optio WG-3 GPS Flash Replacement: adım 6, 1 resimden 1.
    • Remove the ribbon cable that attaches the flash from the circuitry.
  7. Pentax Optio WG-3 GPS Flash Replacement: adım 7, 1 resimden 1.
    • Remove the three 2 mm Phillips #000 screws from the left side of the circuitry.
    • These screws attach the circuit board to the shell of the camera.
    • Remove the circuitry from the front side of the camera
  8. Pentax Optio WG-3 GPS Flash Replacement: adım 8, 1 resimden 1.
    • Find and remove the camera battery.
  9. Pentax Optio WG-3 GPS Flash Replacement: adım 9, 1 resimden 1.
    • Remove the final two 2 mm Phillips #000 screws from the front side of the circuitry.
  10. Pentax Optio WG-3 GPS Flash Replacement: adım 10, 1 resimden 1.
    • Pull the black front panel away from the circuitry.
    • The black panel is attached to the flash and is now ready to be removed and replaced.
    • The sensor is enclosed in the white case.
Sonuç
Cassandra Stec
181 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Spring 2022 IUPUI, Team 3-1, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 205
