Ana içeriğe geç
Pentax Optio WG-3 GPS Lens Assembly Replacement
Neye ihtiyacın var
  1. Pentax Optio WG-3 GPS Lens Assembly  Replacement, Lens Assembly: adım 1, 1 resimden 1.
    • Turn over the camera so the screen is facing up.
    • Remove the four 5 mm Phillips #000 screws that secure the outer cover.
  2. Pentax Optio WG-3 GPS Lens Assembly  Replacement: adım 2, 1 resimden 1.
    • Flip over the camera so the bottom is facing up.
    • Remove the single Phillips #000 screw.
    • Remove the cover.
  3. Pentax Optio WG-3 GPS Lens Assembly  Replacement: adım 3, 1 resimden 1.
    • Remove the eight 5 mm Phillips #000 screws holding the circuitry together.
  4. Pentax Optio WG-3 GPS Lens Assembly  Replacement: adım 4, 1 resimden 1.
    • Carefully remove the circuitry.
  5. Pentax Optio WG-3 GPS Lens Assembly  Replacement: adım 5, 1 resimden 1.
    • Flip the circuitry so that the lens is facing up and the flash component is on your right.
    • Identify the orange ribbon tape surrounding the lens.
  6. Pentax Optio WG-3 GPS Lens Assembly  Replacement: adım 6, 1 resimden 1.
    • There are three 5 mm Phillips #000 screws to be removed on the right side of the lens.
  7. Pentax Optio WG-3 GPS Lens Assembly  Replacement: adım 7, 1 resimden 1.
    • Gently slide the lens piece to the right, remove the tape and take it out.
Sonuç
Garrett Rose
373 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Spring 2022 IUPUI, Team 3-1, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 184
