Ana içeriğe geç
Pentax PZ-10 Button Replacement
Neye ihtiyacın var
    1. Pentax PZ-10 Button Replacement, Top Cover: adım 1, 1 resimden 1.
      • The top cover is one piece encasing the top of the device except the shutter release button and flash.
      FixBot'a Sor
      Yorum Ekle
    2. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: adım 2, 2 resimden 1. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: adım 2, 2 resimden 2.
      • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
      • Using the J0 screwdriver, remove the 6.3 mm screw.
      FixBot'a Sor
      Yorum Ekle
    3. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: adım 3, 2 resimden 1. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: adım 3, 2 resimden 2.
      • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
      • Remove the 6.3 mm screw using a J0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: adım 4, 2 resimden 1. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: adım 4, 2 resimden 2.
      • The next screw is found in the overhanging piece just above the lens.
      • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: adım 5, 2 resimden 1. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: adım 5, 2 resimden 2.
      • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: adım 6, 2 resimden 1. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Gently remove the beige rubber tabs from under the casing by pulling each down using tweezers.
      FixBot'a Sor
      Yorum Ekle
    2. Pentax PZ-10 Button Replacement: adım 7, 1 resimden 1.
      • Remove the 3 buttons by pushing them from under the casing out through the top.
      • Each button is slotted differently, so pay attention to the orientation of each piece.
      FixBot'a Sor
      Yorum Ekle
    3. Pentax PZ-10 Button Replacement, Buttons: adım 8, 1 resimden 1.
      • The buttons are now free to be replaced or cleaned.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jonathan Diaz
213 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 853
