Ana içeriğe geç
Pentax PZ-10 Button Replacement
Neye ihtiyacın var
  1. Pentax PZ-10 Button Replacement, Top Cover: adım 1, 1 resimden 1.
    • The top cover is one piece encasing the top of the device except the shutter release button and flash.
  2. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: adım 2, 2 resimden 1. Pentax PZ-10 Button Replacement, Removing Upper Right Housing Screw: adım 2, 2 resimden 2.
    • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
    • Using the J0 screwdriver, remove the 6.3 mm screw.
  3. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: adım 3, 2 resimden 1. Pentax PZ-10 Button Replacement, Removing Screw in Battery Compartment: adım 3, 2 resimden 2.
    • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
    • Remove the 6.3 mm screw using a J0 screwdriver.
  4. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: adım 4, 2 resimden 1. Pentax PZ-10 Button Replacement, Removing Screw Under Flash Bulb: adım 4, 2 resimden 2.
    • The next screw is found in the overhanging piece just above the lens.
    • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
  5. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: adım 5, 2 resimden 1. Pentax PZ-10 Button Replacement, Pulling Off the Top Cover: adım 5, 2 resimden 2.
    • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
  6. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: adım 6, 2 resimden 1. Pentax PZ-10 Button Replacement, Locate Rubber Tabs: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Gently remove the beige rubber tabs from under the casing by pulling each down using tweezers.
  7. Pentax PZ-10 Button Replacement: adım 7, 1 resimden 1.
    • Remove the 3 buttons by pushing them from under the casing out through the top.
    • Each button is slotted differently, so pay attention to the orientation of each piece.
  8. Pentax PZ-10 Button Replacement, Buttons: adım 8, 1 resimden 1.
    • The buttons are now free to be replaced or cleaned.
Sonuç
Jonathan Diaz
213 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 586
