Ana içeriğe geç
Pentax Spotmatic Bottom Cover Removal
Neye ihtiyacın var
  1. Pentax Spotmatic Bottom Cover Removal, Remove bottom cover: adım 1, 1 resimden 1.
    • Remove two X mm flat head screws.
    • Remove bottom cover.
    • This is an example of a properly functioning mirror charging mechanism.
    • The large gear on the far left is driven by the film advance lever on top of the camera.
    • The long silver lever is the mirror charging lever. It pushes the black bar to the top of the slot when the camera is wound, which charges the main mirror spring.
    • The lever on the right holds the black bar in place while the camera is cocked and ready to shoot.
    • At the end of an exposure, the large black gear pushes the release lever, returning the mirror to the viewing position.
    In early samples, the mirror charging mechanism is quite different.
    Gerjan van Oosten - Yanıt
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sam Gustafson
7.712 İtibar
42 adet Kılavuz yazıldı
1Rehber Yorum
Fantastic way of showing how the priming and firing mechanism works. A wonderful post mark
mark steed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 67
Her zaman: 192
