Ana içeriğe geç
Pentax Spotmatic Light Meter Calibration
Neye ihtiyacın var
  1. Pentax Spotmatic Light Meter Calibration, Open film door: adım 1, 1 resimden 1.
    • Open the flim door.
  2. Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: adım 2, 3 resimden 1. Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: adım 2, 3 resimden 2. Pentax Spotmatic Light Meter Calibration, Remove the rewind knob: adım 2, 3 resimden 3.
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
    • Keep the film door open for the duration of the light meter adjustment. It can be difficult to open without the rewind knob installed.
    • Mount a lens on the camera.
    • Create a scene of known brightness in front of the camera.
    • Adjust the aperture, shutter speed and ISO to achieve proper exposure for the chosen scene.
    • Switch on the light meter.
  3. Pentax Spotmatic Light Meter Calibration, Make adjustments: adım 4, 2 resimden 1. Pentax Spotmatic Light Meter Calibration, Make adjustments: adım 4, 2 resimden 2.
    • Use a pick to adjust the variable resistor through the opening in the top plate.
    • Turn it until the needle in the viewfinder is centered in the opening, indicating a proper exposure.
    • The adjustment resistor shown with the top cover removed.
    • Repeat steps 3 and 4 for several different light levels.
    • Since the Spotmatic only has one adjustment resistor, it may not be possible to center the needle at every light level. Make compromises as necessary.
Sonuç
Sam Gustafson
7.682 İtibar
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 77
Her zaman: 299
