Ana içeriğe geç
Pentax Spotmatic Top Cover Removal
Neye ihtiyacın var
  1. Pentax Spotmatic Top Cover Removal, Remove frame counter: adım 1, 3 resimden 1. Pentax Spotmatic Top Cover Removal, Remove frame counter: adım 1, 3 resimden 2. Pentax Spotmatic Top Cover Removal, Remove frame counter: adım 1, 3 resimden 3.
    • Loosen three grub screws. Do not remove them from the frame counter cover.
    • Lift off frame counter cover.
    • Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
    • Remove the frame counter dial.
    • Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
    • On some Spotmatics, this nut may be reverse threaded. Work carefully.
    • Remove the dial seat.
  2. Pentax Spotmatic Top Cover Removal, Remove advance lever: adım 2, 3 resimden 1. Pentax Spotmatic Top Cover Removal, Remove advance lever: adım 2, 3 resimden 2. Pentax Spotmatic Top Cover Removal, Remove advance lever: adım 2, 3 resimden 3.
    • Remove three 2.3 mm flat head screws.
    • Use a pick to rotate the retaining washer until the lobed sections are free.
    • Lift off the advance lever.
    • Remove the plastic shim washer.
  3. Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: adım 3, 3 resimden 1. Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: adım 3, 3 resimden 2. Pentax Spotmatic Top Cover Removal, Remove shutter speed dial: adım 3, 3 resimden 3.
    • Remove one 2.8 mm pin head screw.
    • The dial assembly is spring loaded. Keep two fingers on top of the dial as you are loosening the screw to prevent it from popping off.
    • Remove the shutter speed dial.
    • Remove the ISO dial.
    • Remove the internal spring.
    • Remove the dial housing.
  4. Pentax Spotmatic Top Cover Removal, Installation Notes: Shutter Speed Dial: adım 4, 2 resimden 1. Pentax Spotmatic Top Cover Removal, Installation Notes: Shutter Speed Dial: adım 4, 2 resimden 2.
    • The hole in the dial housing needs to go over the tab on the speed resistor.
    • The tab on the ISO dial needs to mate with the hole in the dial housing.
    • It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
  5. Pentax Spotmatic Top Cover Removal, Remove film winder assembly: adım 5, 3 resimden 1. Pentax Spotmatic Top Cover Removal, Remove film winder assembly: adım 5, 3 resimden 2. Pentax Spotmatic Top Cover Removal, Remove film winder assembly: adım 5, 3 resimden 3.
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
  6. Pentax Spotmatic Top Cover Removal, Remove top cover: adım 6, 2 resimden 1. Pentax Spotmatic Top Cover Removal, Remove top cover: adım 6, 2 resimden 2.
    • Remove one 3.0 mm flat head screw.
    • Remove top cover.
Sonuç
Sam Gustafson
7.712 İtibar
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 37
Son 30 gün: 97
Her zaman: 334
