Ana içeriğe geç
Pentax Spotmatic Viewfinder Removal
Neye ihtiyacın var
  1. Pentax Spotmatic Viewfinder Removal, Remove frame counter: adım 1, 3 resimden 1. Pentax Spotmatic Viewfinder Removal, Remove frame counter: adım 1, 3 resimden 2. Pentax Spotmatic Viewfinder Removal, Remove frame counter: adım 1, 3 resimden 3.
    • Loosen three grub screws. Do not remove them from the frame counter cover.
    • Lift off frame counter cover.
    • Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
    • Remove the frame counter dial.
    • Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
    • On some Spotmatics, this nut may be reverse threaded. Work carefully.
    • Remove the dial seat.
  2. Pentax Spotmatic Viewfinder Removal, Remove advance lever: adım 2, 3 resimden 1. Pentax Spotmatic Viewfinder Removal, Remove advance lever: adım 2, 3 resimden 2. Pentax Spotmatic Viewfinder Removal, Remove advance lever: adım 2, 3 resimden 3.
    • Remove three 2.3 mm flat head screws.
    • Use a pick to rotate the retaining washer until the lobed sections are free.
    • Lift off the advance lever.
    • Remove the plastic shim washer.
  3. Pentax Spotmatic Viewfinder Removal, Remove shutter speed dial: adım 3, 3 resimden 1. Pentax Spotmatic Viewfinder Removal, Remove shutter speed dial: adım 3, 3 resimden 2. Pentax Spotmatic Viewfinder Removal, Remove shutter speed dial: adım 3, 3 resimden 3.
    • Remove one 2.8 mm pin head screw.
    • The dial assembly is spring loaded. Keep two fingers on top of the dial as you are loosening the screw to prevent it from popping off.
    • Remove the shutter speed dial.
    • Remove the ISO dial.
    • Remove the internal spring.
    • Remove the dial housing.
  4. Pentax Spotmatic Viewfinder Removal, Installation Notes: Shutter Speed Dial: adım 4, 2 resimden 1. Pentax Spotmatic Viewfinder Removal, Installation Notes: Shutter Speed Dial: adım 4, 2 resimden 2.
    • The hole in the dial housing needs to go over the tab on the speed resistor.
    • The tab on the ISO dial needs to mate with the hole in the dial housing.
    • It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
  5. Pentax Spotmatic Viewfinder Removal, Remove film winder assembly: adım 5, 3 resimden 1. Pentax Spotmatic Viewfinder Removal, Remove film winder assembly: adım 5, 3 resimden 2. Pentax Spotmatic Viewfinder Removal, Remove film winder assembly: adım 5, 3 resimden 3.
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
  6. Pentax Spotmatic Viewfinder Removal, Remove top cover: adım 6, 2 resimden 1. Pentax Spotmatic Viewfinder Removal, Remove top cover: adım 6, 2 resimden 2.
    • Remove one 3.0 mm flat head screw.
    • Remove top cover.
  7. Pentax Spotmatic Viewfinder Removal, Unsolder meter circuit: adım 7, 2 resimden 1. Pentax Spotmatic Viewfinder Removal, Unsolder meter circuit: adım 7, 2 resimden 2.
    • Unscrew or unsolder one black wire. This is the main power coming from the meter switch on the side of the mirror box.
    • Unscrew one blue wire. This is the ground wire that connects the meter circuit to the body of the camera.
    • Unsolder one yellow and one black wire from the speed resistor.
  8. Pentax Spotmatic Viewfinder Removal, Remove viewfinder assembly: adım 8, 2 resimden 1. Pentax Spotmatic Viewfinder Removal, Remove viewfinder assembly: adım 8, 2 resimden 2.
    • Remove three 5.7 mm flat head screws.
    • Lift out the viewfinder assembly.
    • The pentaprism, eye piece and meter circuit will come out with the viewfinder.
Sonuç
Sam Gustafson
7.712 İtibar
42 adet Kılavuz yazıldı
1Rehber Yorum
Very clear description of the procedure to remove the top cover and of course the pentaprism and view finder . Great photographs to accompany each step and so well presented, could not be bettered. So that many thanks indeed - very very helpful. regards mark
mark steed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 59
Her zaman: 217
