Ana içeriğe geç
Pentax ZX-5n Flash Pivot Replacement
Neye ihtiyacın var
    1. Pentax ZX-5n Flash Pivot Replacement, Remove back cover: adım 1, 1 resimden 1.
      • Push down on the screw to depress the spring loaded hinge and release the door.
      FixBot'a Sor
      Yorum Ekle
    2. Pentax ZX-5n Flash Pivot Replacement, Remove bottom cover: adım 2, 1 resimden 1.
      • Remove six 5.3 mm #00 screws.
      • Remove one 3.4 mm #00 screw.
      • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
      FixBot'a Sor
      Yorum Ekle
    3. Pentax ZX-5n Flash Pivot Replacement, Remove left front cover: adım 3, 1 resimden 1.
      • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
      • Remove one 7.3 mm #00 screw.
      • Remove the remote trigger cover.
      FixBot'a Sor
      Yorum Ekle
    4. Pentax ZX-5n Flash Pivot Replacement, Remove front cover: adım 4, 2 resimden 1. Pentax ZX-5n Flash Pivot Replacement, Remove front cover: adım 4, 2 resimden 2.
      • Remove two 5.3 mm #00 screw.
      • Gently lift up on the flash housing to help remove the cover if necessary.
      FixBot'a Sor
      Yorum Ekle
    5. Pentax ZX-5n Flash Pivot Replacement, Remove right front cover: adım 5, 1 resimden 1.
      • Remove two 3.9 mm #00 screws.
      FixBot'a Sor
      Yorum Ekle
    1. Pentax ZX-5n Flash Pivot Replacement, Remove eye cup: adım 6, 1 resimden 1.
      • Slide the eye cup up and off to access the screws underneath.
      FixBot'a Sor
      Yorum Ekle
    2. Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: adım 7, 3 resimden 1. Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: adım 7, 3 resimden 2. Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: adım 7, 3 resimden 3.
      • Remove two 5.3 mm #00 screws by the eyepiece.
      • Remove one 6.8 mm #00 screw in the battery compartment.
      • Remove one 7.0 mm #00 screw near the take up spool.
      FixBot'a Sor
      Yorum Ekle
    3. Pentax ZX-5n Flash Pivot Replacement, Lift top cover: adım 8, 1 resimden 1.
      • Lift the cover so it is just free of the body. It is still attached by several wires.
      FixBot'a Sor
      Yorum Ekle
    4. Pentax ZX-5n Flash Pivot Replacement, Discharge flash capacitors: adım 9, 1 resimden 1.
      • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
      • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
      FixBot'a Sor
      Yorum Ekle
    5. Pentax ZX-5n Flash Pivot Replacement, Unsolder flash connections: adım 10, 1 resimden 1.
      • Unsolder one green wire.
      • Unsolder one blue wire.
      • Unsolder one brown wire.
      • Unsolder one black wire.
      FixBot'a Sor
      Yorum Ekle
    6. Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: adım 11, 3 resimden 1. Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: adım 11, 3 resimden 2. Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: adım 11, 3 resimden 3.
      • Pull black wire out from its routed location.
      • Unsolder flex connector
      • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
      • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
      FixBot'a Sor
      Yorum Ekle
    1. Pentax ZX-5n Flash Pivot Replacement, Pop up the flash: adım 12, 1 resimden 1.
      • Push the release button to pop up the flash.
      FixBot'a Sor
      Yorum Ekle
    2. Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: adım 13, 3 resimden 1. Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: adım 13, 3 resimden 2. Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: adım 13, 3 resimden 3.
      • Remove two 2.9mm #000 screws.
      • Remove two 4.4 mm #00 screws.
      • Close the flash and lift off the top cover.
      FixBot'a Sor
      Yorum Ekle
    3. Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: adım 14, 3 resimden 1. Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: adım 14, 3 resimden 2. Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: adım 14, 3 resimden 3.
      • Remove the latch spring.
      • Remove the latch plate. The flash will try to pop up when it is removed.
      FixBot'a Sor
      Yorum Ekle
    4. Pentax ZX-5n Flash Pivot Replacement, Remove pop up spring: adım 15, 1 resimden 1.
      • Release the spring arm from the post.
      • Remove the pop up spring.
      FixBot'a Sor
      Yorum Ekle
    5. Pentax ZX-5n Flash Pivot Replacement, Remove the flash pivot: adım 16, 2 resimden 1. Pentax ZX-5n Flash Pivot Replacement, Remove the flash pivot: adım 16, 2 resimden 2.
      • Remove one 3.3 mm #00 screw.
      • Hold the pivot in place while unscrewing.
      FixBot'a Sor
      Yorum Ekle
    6. Pentax ZX-5n Flash Pivot Replacement, Install screw: adım 17, 1 resimden 1.
      • When using the 3D printed part supplied on the device page, install a 4mm #00 screw in the end of the pivot to hold it together.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Sam Gustafson
14.444 İtibar
78 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 65
Her zaman: 1,253
