Ana içeriğe geç
Performance Tool W50042 Trigger Switch Replacement
Neye ihtiyacın var
  1. Performance Tool W50042 Trigger Switch Replacement, Trigger Switch: adım 1, 1 resimden 1.
    • Remove the battery by pressing the yellow tabs on both sides, then pull the battery out.
  2. Performance Tool W50042 Trigger Switch Replacement: adım 2, 3 resimden 1. Performance Tool W50042 Trigger Switch Replacement: adım 2, 3 resimden 2. Performance Tool W50042 Trigger Switch Replacement: adım 2, 3 resimden 3.
    • Remove the nine 1/2 inch Phillips head screws.
  3. Performance Tool W50042 Trigger Switch Replacement: adım 3, 3 resimden 1. Performance Tool W50042 Trigger Switch Replacement: adım 3, 3 resimden 2. Performance Tool W50042 Trigger Switch Replacement: adım 3, 3 resimden 3.
    • Use a T-25 hex bit to remove four 1'1/2 hex head screws.
  4. Performance Tool W50042 Trigger Switch Replacement: adım 4, 3 resimden 1. Performance Tool W50042 Trigger Switch Replacement: adım 4, 3 resimden 2. Performance Tool W50042 Trigger Switch Replacement: adım 4, 3 resimden 3.
    • Remove the shaft cover.
  5. Performance Tool W50042 Trigger Switch Replacement: adım 5, 3 resimden 1. Performance Tool W50042 Trigger Switch Replacement: adım 5, 3 resimden 2. Performance Tool W50042 Trigger Switch Replacement: adım 5, 3 resimden 3.
    • Remove the case.
  6. Performance Tool W50042 Trigger Switch Replacement: adım 6, 3 resimden 1. Performance Tool W50042 Trigger Switch Replacement: adım 6, 3 resimden 2. Performance Tool W50042 Trigger Switch Replacement: adım 6, 3 resimden 3.
    • Lift the trigger switch to remove the direction switch.
  7. Performance Tool W50042 Trigger Switch Replacement: adım 7, 3 resimden 1. Performance Tool W50042 Trigger Switch Replacement: adım 7, 3 resimden 2. Performance Tool W50042 Trigger Switch Replacement: adım 7, 3 resimden 3.
    • Unscrew the red wire from the motor (Phillips head screw 1/4 inch).
  8. Performance Tool W50042 Trigger Switch Replacement: adım 8, 3 resimden 1. Performance Tool W50042 Trigger Switch Replacement: adım 8, 3 resimden 2. Performance Tool W50042 Trigger Switch Replacement: adım 8, 3 resimden 3.
    • Pick up the motor and remove the black wire (Phillips head screw 1/4 inch).
Sonuç
Bir başkası bu kılavuzu tamamladı.
David
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 264
