Ana içeriğe geç
Petmate 29027 Fountain Lid and Pump Replacement
Neye ihtiyacın var
  1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: adım 1, 3 resimden 1. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: adım 1, 3 resimden 2. Petmate 29027 Fountain Lid and Pump Replacement, Fountain Lid and Pump: adım 1, 3 resimden 3.
    • Unplug the fountain from the electrical source and disconnect the inline plug.
    • Remove the lid.
    • Empty water from the fountain
    • Reach in the bowl and lift up the pump.
  2. Petmate 29027 Fountain Lid and Pump Replacement: adım 2, 3 resimden 1. Petmate 29027 Fountain Lid and Pump Replacement: adım 2, 3 resimden 2. Petmate 29027 Fountain Lid and Pump Replacement: adım 2, 3 resimden 3.
    • Unclip the lid and intake plate using a fingernail.
  3. Petmate 29027 Fountain Lid and Pump Replacement: adım 3, 2 resimden 1. Petmate 29027 Fountain Lid and Pump Replacement: adım 3, 2 resimden 2.
    • Pry out the impeller (4 white bladed propellers) which is held in place magnetically.
    • You can use a fingernail or small needle nose pliers to get under the plastic blade and lift it out.
  4. Petmate 29027 Fountain Lid and Pump Replacement: adım 4, 3 resimden 1. Petmate 29027 Fountain Lid and Pump Replacement: adım 4, 3 resimden 2. Petmate 29027 Fountain Lid and Pump Replacement: adım 4, 3 resimden 3.
    • Clean the parts with warm soapy water and reassemble them.
    • Be sure to rinse thoroughly with fresh water.
    • Cleaning the motor with white vinegar (150ml) can increase disinfecting and hard water removal.
  5. Petmate 29027 Fountain Lid and Pump Replacement: adım 5, 2 resimden 1. Petmate 29027 Fountain Lid and Pump Replacement: adım 5, 2 resimden 2.
    • Replace the pump into the original location.
    • Press down on the pump to engage the suction cups.
    • Place the fountain lid in the right place.
  6. Petmate 29027 Fountain Lid and Pump Replacement: adım 6, 2 resimden 1. Petmate 29027 Fountain Lid and Pump Replacement: adım 6, 2 resimden 2.
    • Replug the fountain into electricity.
    • Add water as needed.
    • Never let the water level fall lower than the min fill line.
Bitiş Çizgisi
Shidie Ren
133 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 510
