Ana içeriğe geç
Petnet SmartFeeder SF10E Battery Replacement
Neye ihtiyacın var
  1. Petnet SmartFeeder SF10E Battery Replacement, Battery: adım 1, 3 resimden 1. Petnet SmartFeeder SF10E Battery Replacement, Battery: adım 1, 3 resimden 2. Petnet SmartFeeder SF10E Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
    • Remove the metal tray by using both hands and pulling out the bowl towards you.
  2. Petnet SmartFeeder SF10E Battery Replacement: adım 2, 2 resimden 1. Petnet SmartFeeder SF10E Battery Replacement: adım 2, 2 resimden 2.
    • Turn the bowl tray side down by using both hands.
    • Remove seven 11 mm screws by using the Phillips #1 screwdriver.
  3. Petnet SmartFeeder SF10E Battery Replacement: adım 3, 2 resimden 1. Petnet SmartFeeder SF10E Battery Replacement: adım 3, 2 resimden 2.
    • Take the battery out of the SmartBowl with tweezers, avoid pulling on any wires.
    • Hold the SmartBowl down using one hand while using the other hand to remove the battery.
  4. Petnet SmartFeeder SF10E Battery Replacement: adım 4, 2 resimden 1. Petnet SmartFeeder SF10E Battery Replacement: adım 4, 2 resimden 2.
    • Remove the tape, closest to the four white connectors, with your hands.
    • Keep the wires attached to the tape for easy reassembly.
  5. Petnet SmartFeeder SF10E Battery Replacement: adım 5, 2 resimden 1. Petnet SmartFeeder SF10E Battery Replacement: adım 5, 2 resimden 2.
    • Trace the wires with your hands from the battery to the motherboard.
    • Detach the three-prong connector between the battery and the motherboard by pulling the white connectors with your hands.
    • Hold on to the sockets on the motherboard or you could accidentally pull off the entire assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kristin Villanueva
370 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G7, White Fall 2018 Cal Poly, Team S13-G7, White Fall 2018 üyesi
CPSU-WHITE-F18S13G7
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 547
