Giriş
Use this guide to replace your charging assembly if it is damaged and cannot connect to the USB charging cable. When working with electrical components, use steady hands and touch as little of the circuitry as possible.
Neye ihtiyacın var
Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
Remove the metal tray by using both hands and pulling out the bowl towards you.
Use the nylon spudger to remove the charging assembly from the SmartBowl.
