Ana içeriğe geç
Peugeot Boxer Headlamp Bulb Replacement
Neye ihtiyacın var
  1. Peugeot Boxer Headlamp Bulb Replacement, Bonnet Catch: adım 1, 1 resimden 1.
    • Open the passenger side door to find the bonnet release catch.
    • Pull the catch down and towards you to release the bonnet of the van.
  2. Peugeot Boxer Headlamp Bulb Replacement, Secondary Bonnet Catch: adım 2, 1 resimden 1.
    • Once the bonnet is loosened, find the yellow handle of the secondary bonnet catch by feeling underneath
    • Once you locate the catch, push the bonnet catch upwards, this will release the bonnet
  3. Peugeot Boxer Headlamp Bulb Replacement, Open Bonnet: adım 3, 1 resimden 1.
    • Use the strut, located to the right of the hood to prop open the bonnet.
    • Make sure the strut is secure to the hood! If the strut comes down, this may damage your car and strut!
  4. Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: adım 4, 2 resimden 1. Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: adım 4, 2 resimden 2.
    • Remove the two Torx bolts holding the headlamp assembly at each corner.
  5. Peugeot Boxer Headlamp Bulb Replacement, Slide Headlamp Out: adım 5, 1 resimden 1.
    • Gently slide headlamp assembly out
    • Make sure to move the headlight diagonally towards you and towards the centre of the vehicle
  6. Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: adım 6, 2 resimden 1. Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: adım 6, 2 resimden 2.
    • Pull the tab on rubber cap, revealing the back of the headlamp bulb.
  7. Peugeot Boxer Headlamp Bulb Replacement, Disconnect Bulb: adım 7, 1 resimden 1.
    • Remove the electrical connection from the old bulb (it should just pull off).
    • Make a note of which way up the plug was for when you connect everything back up again.
  8. Peugeot Boxer Headlamp Bulb Replacement, Remove Bulb: adım 8, 1 resimden 1.
    • With needle-nosed pliers, carefully 'wiggle' the old bulb out from its housing.
  9. Peugeot Boxer Headlamp Bulb Replacement, New Bulb: adım 9, 1 resimden 1.
    • Locate your new bulb. Taking care to make sure it is the right way up, push it firmly into place until you feel it clip in.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kit Marsden
520 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 51
Son 30 gün: 320
Her zaman: 5,913
