Ana içeriğe geç
Philips BiPAP S/T Blower Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
Videoya Genel Bakış
  1. Philips BiPAP S/T Blower  Replacement, Blower: adım 1, 1 resimden 1.
    • Remove the UI Knob by pulling it straight out.
  2. Philips BiPAP S/T Blower  Replacement: adım 2, 1 resimden 1.
    • Remove the top cover by using a Torx T15 to remove the 2 screws on the back of the enclosure.
  3. Philips BiPAP S/T Blower  Replacement: adım 3, 1 resimden 1.
    • Remove the Main PCA by removing the wiring harnesses and squeezing the 2 standoffs in the corners of the board.
  4. Philips BiPAP S/T Blower  Replacement: adım 4, 1 resimden 1.
    • Remove the Blower Cap by using the T8 Torx screwdriver to remove the 7 screws that secure the Cap to the enclosure.
    • Lift the Blower Assembly out of the blower housing.
    • Remove the blower Outlet Bellows from the blower assembly.
    • Place the New outlet bellows onto the blower assembly.
  5. Philips BiPAP S/T Blower  Replacement: adım 7, 1 resimden 1.
    • Align the stands located on the bottom of the blower assembly with the holes in the blower housing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Benjamin LaVigna
243 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G3, Paton Spring 2020 Cal Poly, Team S7-G3, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G3
3 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
this was super helpful. i yanked a working motor/blower from a slightly older system one unit that had a dead humidifier circuit(found it had melted the connector inside) and moved it to my newer bipap unit. works great, dead silent. mine had bad bearings…so loud. great article. thank you for saving me money, time…..SLEEP!
Jon Harmon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 2,760
