Ana içeriğe geç
Philips DC320 37 Bottom Button Circuit Board Replacement
Neye ihtiyacın var
  1. Philips DC320 37 Bottom Button Circuit Board Replacement, Docking entertainment system: adım 1, 1 resimden 1.
    • Pry off the four white feet with the pointed end of the spudger
    FixBot'a Sor
  2. Philips DC320 37 Bottom Button Circuit Board Replacement: adım 2, 1 resimden 1.
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    FixBot'a Sor
  3. Philips DC320 37 Bottom Button Circuit Board Replacement: adım 3, 1 resimden 1.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
    FixBot'a Sor
  4. Philips DC320 37 Bottom Button Circuit Board Replacement: adım 4, 3 resimden 1. Philips DC320 37 Bottom Button Circuit Board Replacement: adım 4, 3 resimden 2. Philips DC320 37 Bottom Button Circuit Board Replacement: adım 4, 3 resimden 3.
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
    FixBot'a Sor
  5. Philips DC320 37 Bottom Button Circuit Board Replacement, Bottom Button Circuit Board: adım 5, 1 resimden 1.
    • Unscrew the ten 6 mm Phillips #00 screws holding the board in place.
    FixBot'a Sor
  6. Philips DC320 37 Bottom Button Circuit Board Replacement: adım 6, 1 resimden 1.
    • Pull the board out from the dock
    FixBot'a Sor
Sonuç
Greg Lane
39 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G48
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
My philips dc 320 /37 A do not sown time digits and frecvency digits . Where can I find schematic diagram?
Thank you
chioreangheorghe - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 34
Her zaman: 1,083
