Ana içeriğe geç
Philips DC320 37 Connector Replacement
Neye ihtiyacın var
  1. Philips DC320 37 Connector Replacement, Docking entertainment system: adım 1, 1 resimden 1.
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Connector Replacement: adım 2, 1 resimden 1.
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Connector Replacement: adım 3, 1 resimden 1.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Connector Replacement: adım 4, 3 resimden 1. Philips DC320 37 Connector Replacement: adım 4, 3 resimden 2. Philips DC320 37 Connector Replacement: adım 4, 3 resimden 3.
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Connector Replacement, Connector: adım 5, 1 resimden 1.
    • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
  6. Philips DC320 37 Connector Replacement: adım 6, 1 resimden 1.
    • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
    • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
  7. Philips DC320 37 Connector Replacement: adım 7, 3 resimden 1. Philips DC320 37 Connector Replacement: adım 7, 3 resimden 2. Philips DC320 37 Connector Replacement: adım 7, 3 resimden 3.
    • Turn the dock so that you are looking at the front of the dock.
    • Pull out the black U-shaped piece.
    • Pull out the iPhone/iPod support cradle.
    • Pull out the two springs.
  8. Philips DC320 37 Connector Replacement: adım 8, 1 resimden 1.
    • Turn the dock so that you are looking at the bottom of the dock.
    • Pop out the black connector frame and attached circuit board from the body of the dock.
Sonuç
Greg Lane
39 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G48
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 1,233
