Ana içeriğe geç
Philips DC320 37 Speaker Replacement
Neye ihtiyacın var
  1. Philips DC320 37 Speaker Replacement, Docking entertainment system: adım 1, 1 resimden 1.
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Speaker Replacement: adım 2, 1 resimden 1.
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Speaker Replacement: adım 3, 1 resimden 1.
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Speaker Replacement: adım 4, 3 resimden 1. Philips DC320 37 Speaker Replacement: adım 4, 3 resimden 2. Philips DC320 37 Speaker Replacement: adım 4, 3 resimden 3.
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
  6. Philips DC320 37 Speaker Replacement: adım 6, 3 resimden 1. Philips DC320 37 Speaker Replacement: adım 6, 3 resimden 2. Philips DC320 37 Speaker Replacement: adım 6, 3 resimden 3.
    • Slide the back panel towards top of the device and lift away from the device to detach back panel.
  7. Philips DC320 37 Speaker Replacement: adım 7, 1 resimden 1.
    • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
  8. Philips DC320 37 Speaker Replacement: adım 8, 2 resimden 1. Philips DC320 37 Speaker Replacement: adım 8, 2 resimden 2.
    • Slide the speaker towards the bottom of the device to remove.
Sonuç
Graham Rolph
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G48
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 905
