Giriş
Ensure to have your replacement display lying next to you before you start removing the defective one.
You should also have a little bowl ready to set aside screws and other small parts.
Neye ihtiyacın var
Put on the Anti-Static Wrist Strap and clamp the end of the band to an unpainted spot of a radiator.
Unscrew the six Torx #4 (5,3 mm) screws from both sides of the device
Neredeyse bitti!
To reassemble your device, follow these instructions in reverse order beginning with step 8.
Sonuç
