Ana içeriğe geç
Philips DVP5992-F7 Audio Video Port Replacement
Neye ihtiyacın var
  1. Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: adım 1, 3 resimden 1. Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: adım 1, 3 resimden 2. Philips DVP5992-F7 Audio Video Port Replacement, Audio/Video Port: adım 1, 3 resimden 3.
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Audio Video Port Replacement: adım 2, 2 resimden 1. Philips DVP5992-F7 Audio Video Port Replacement: adım 2, 2 resimden 2.
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Audio Video Port Replacement: adım 3, 3 resimden 1. Philips DVP5992-F7 Audio Video Port Replacement: adım 3, 3 resimden 2. Philips DVP5992-F7 Audio Video Port Replacement: adım 3, 3 resimden 3.
    • Unplug the one ribbon wire and the five bundled cable connectors that are plugged into the motherboard.
  4. Philips DVP5992-F7 Audio Video Port Replacement: adım 4, 1 resimden 1.
    • Remove the three 4.76 mm #1 Phillips head screws located on the back of the DVD player.
  5. Philips DVP5992-F7 Audio Video Port Replacement: adım 5, 1 resimden 1.
    • Remove the two 7.94 mm #1 Phillips head screws from the motherboard.
  6. Philips DVP5992-F7 Audio Video Port Replacement: adım 6, 1 resimden 1.
    • Remove the motherboard from the DVD player.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 330
