Ana içeriğe geç
Philips DVP5992-F7 Power Cord Replacement
Neye ihtiyacın var
  1. Philips DVP5992-F7 Power Cord Replacement, Power Cord: adım 1, 3 resimden 1. Philips DVP5992-F7 Power Cord Replacement, Power Cord: adım 1, 3 resimden 2. Philips DVP5992-F7 Power Cord Replacement, Power Cord: adım 1, 3 resimden 3.
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 Power Cord Replacement: adım 2, 2 resimden 1. Philips DVP5992-F7 Power Cord Replacement: adım 2, 2 resimden 2.
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 Power Cord Replacement: adım 3, 3 resimden 1. Philips DVP5992-F7 Power Cord Replacement: adım 3, 3 resimden 2. Philips DVP5992-F7 Power Cord Replacement: adım 3, 3 resimden 3.
    • Locate the power cable connector inside the DVD player.
    • Pinch down on both sides of the cable connector.
    • Gently pull upwards on the cable connector while wiggling it to remove it from the DVD player.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 414
