Ana içeriğe geç
Philips DVP5992-F7 Tray Replacement
Neye ihtiyacın var
  1. Philips DVP5992-F7 Tray Replacement, Tray: adım 1, 3 resimden 1. Philips DVP5992-F7 Tray Replacement, Tray: adım 1, 3 resimden 2. Philips DVP5992-F7 Tray Replacement, Tray: adım 1, 3 resimden 3.
    • Plug in the DVD player.
    • Press the eject button to open the tray.
    • Push up on the tray faceplate to remove it.
  2. Philips DVP5992-F7 Tray Replacement: adım 2, 2 resimden 1. Philips DVP5992-F7 Tray Replacement: adım 2, 2 resimden 2.
    • Press the eject button to re-insert the tray.
    • Unplug the DVD player after the tray is closed.
  3. Philips DVP5992-F7 Tray Replacement: adım 3, 3 resimden 1. Philips DVP5992-F7 Tray Replacement: adım 3, 3 resimden 2. Philips DVP5992-F7 Tray Replacement: adım 3, 3 resimden 3.
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  4. Philips DVP5992-F7 Tray Replacement: adım 4, 2 resimden 1. Philips DVP5992-F7 Tray Replacement: adım 4, 2 resimden 2.
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  5. Philips DVP5992-F7 Tray Replacement: adım 5, 3 resimden 1. Philips DVP5992-F7 Tray Replacement: adım 5, 3 resimden 2. Philips DVP5992-F7 Tray Replacement: adım 5, 3 resimden 3.
    • Locate the motherboard within the DVD player.
    • Firmly grasp the ribbon wire and unplug it from the motherboard.
  6. Philips DVP5992-F7 Tray Replacement: adım 6, 2 resimden 1. Philips DVP5992-F7 Tray Replacement: adım 6, 2 resimden 2.
    • Firmly grasp the bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the bundled cable connector from the motherboard.
  7. Philips DVP5992-F7 Tray Replacement: adım 7, 2 resimden 1. Philips DVP5992-F7 Tray Replacement: adım 7, 2 resimden 2.
    • Firmly grasp the second bundled cable connector that attaches the tray to the motherboard.
    • Gently pull upwards to remove the second bundled cable connector from the motherboard.
  8. Philips DVP5992-F7 Tray Replacement: adım 8, 2 resimden 1. Philips DVP5992-F7 Tray Replacement: adım 8, 2 resimden 2.
    • Remove the 9.0 mm #1 Phillips head screw that holds the tray to the DVD player.
  9. Philips DVP5992-F7 Tray Replacement: adım 9, 2 resimden 1. Philips DVP5992-F7 Tray Replacement: adım 9, 2 resimden 2.
    • Lift the tray out of the DVD player from the back.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 492
